Fuel return plumbing question
Hi all
86 SIII
I want to remove fuel return valves in rear wheel wells to inspect but my tanks are both near full
I was wondering where the return pipe actually is position at the tank. If on very top, removing valve should be easy. But if pipe entrance is below fuel level in tank I would expect a bunch of gas pouring out the hose if I disconnect valve
Randy
86 SIII
Randy
Whilst this is true, one can clamp the flexible hoses at either end and then remove each valve for testing. The tool to use is the same as sold for clamping flexible brake hoses when a caliper is to be removed.
Thanks gents! My thought was to clamp off as plan B too
They were replaced by PO a few years ago but car not driven much. One is whining a bit and I am guessing not opening fully
I gotta get em off either way if I replace or try to fix
I was told that a good cleaning and back flow might tevive
Randy
Randy
millster
11-19-2013 10:35 PM
FastKat
09-17-2013 09:04 AM
