Fuel Sending unit
Received 9,321 Likes
Mine (series 2) is accessed through the tail light, I don't know if that changed with series 3.
Tail lights are easy to remove and take a look. You might be surprised to find it's only a matter of the ground wire falling off. There's a rat's nest of wires there, for the tail light complex, marker lights and the fuel sender. They all share a common ground through a bullet connector. At least mine do.
If you decide to remove the sender be sure you drain the tank below that level before you break into it though.
Yes, it can be done through the tail light! Just don't make the mistake I made, make sure tank is almost empty when you do the job! I posted about what happened to me in a post that is labeled "engage your brain before working on your car! "
Cannot link to it from my phone, just know that a garage floor flooded.with gasoline is scary indeed!!!
Received 2,399 Likes
Yeah, it is a twist and lock device.
Elegant. Find a large worn out socket. Grind it with gaps and teeth to engage the lugs on the sender. Offer it up, push and twist.
Not so much: a chunk of tubing with the end cut to fit the lugs. Perpindicular hole for a lever to twist.
Not sure if there is enough room for a brass drift to drive the lugs home.
Carl
Carl
