Hello you guys.
I own a Jaguar XJ6C 1975 under renovation
I'm working now on the fuel system. There is a unit that is mounted under the front right wing of the car. It connects to the fuel system for carburettors. What is the role of this unit and whether it is necessary in a warm country like mine (Israel).
I would appreciate an answer
Thats the vapor canister. It stores fuel vapors that gas off from the cars fuel system when it's parked. They get absorbed and stored by the canister which is filled with charcoal aggregate. When the engine is started and running it draws in a slight amount of air flow through the canister to purge the vapors. This type of system is probably more necessary in a warm climate where fuel is more likely to vaporize at higher temperatures.
also known as Charcoal Canister. it collects fuel vapors from the tanks, then passes the vapor to the engine intake through pressure check valves to be burned in the combustion.
if it did not have liquid fuel inside it when removed, it is probably good.
I've considered this as a part of the emision control system In olden days, tanks vented to the atmosphere. this device directs the fumes to the engine via the cannister.
Very similar to the GM product in my parts shed. It in turn very similar to the "Jagguar" unit in my newer Jaguar.
Is there any issue with removing this charcoal canister? I changed my car to triple SU's and removed all of the emissions equipment. My canister was full of oil and dripping on my RF brakes. Charcoal was non-existent. My vent hoses from the tanks are simply venting where the canister used to be. Hasn't seen any above 70 F degree days yet...
