Fuel tank drain gaskets
Hello,
does anyone know where I can source the gasket for the fuel tank drains on a '73 XJ6? I pulled the drains and flushed the tanks of some nasty rust. Now, of curse, the drains are leaking. I can't seem to find the gaskets anywhere; am I better off buying some Napa gasket material and making my own?
Thanks!
-Michael
Thanks!
-Michael
RE: Fuel tank drain gaskets
Also, does anyone happen to have a fuel line routing diagram? I'm stumped on where the fuel goes into the carbs... I just got one tank hooked up and pumping, but the fuel is going through the fuel cooler and then dumping- the other end of the line off the fuel cooler isn't attached. I have a return coming off the fuel bowls, in the center, to a Y that comes up to a tube that goes up and over the engine and down into the driver's wheel well- I'm guessing this is the overflow return?
My only experience has been with autolite carbs and the odd quadrajet... Any help is greatly appreciated!
-Michal
-Michal
If you don't know the actual name of a particular part, sometimes its best to just call to discuss your order. They'll know what you mean. From my experience, before I open my fuel tank drains, I always make sure to have a new gasket available, otherwise you'll get exactly what you did, a leak.
Well,
I'm set up to get some gaskets soon... the only problem is, I just tried to remove the plug that I screwed in, and it's just spinning in the bore... I think I stripped the darn threads somehow. I guess they're just that thin. I suppose I have one usable gas tank, at least, until I can fix the other or get a new one...
-Michael
-Michael
gaskets
phoenix-stripped threads-that sucks!
I'm a little late joining here to help you out, but in my intro I mentioned that the distributor gasket from a SBC fit perfectly. You actually have to thread it on to get it on. I put some Right Stuff silicone on as well to help it seal. I come from the sbc world, so I had several extras sitting in my gasket box. If you don't have any, check with a friend. Thought they would at least be a good temp fix, but I actually haven't even replaced mine yet after three years, with no leaks.
Hopefully this helps someone else out down the road.
Dimitrigregorio
17
09-05-2019 03:47 AM
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
