Fuel tank lid open and whooooosh!
Received 10,898 Likes
If you look on the fenderwell behind the right front tire you'll see the vent lines and vapor canister.
One the the small steel pipes is clearly routed in a horizontal fashion....that's the one that goes back to the fuek tanks. A check valve is attched to this pipe with a vacuum hose. Remove the valve and/or disconnect it so that the pipe is open to atmosphere.
Let us know if the whoosh goes away.
I should note that a small whoosh is normal. But yours sounds like a really big whoosh!
Replacing the little fuel vapor pressure valve Doug mentioned cured the 'whoosh' from my passenger side tank. Finding a replacement valve can be tough; I found a used one.
I've read that a temporary (or permanent if you prefer) solution can be to drill through the valve to open the blockage. The valve won't work as designed anymore; but I think the only detrimental effect is to reduce the level of fuel vapors that get scrubbed by the charcoal canister.
I tried and tried to get mine cleaned out and working, but it was no use. Finally I drilled thru the insides. Vapors still go to the canister, just no more check valve. This also stopped the fuel smell I was getting in the trunk after long runs.
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
