fuel tank problem
Fred
See Diagram item # 12 Change-over valve, leaking or stuck half-way open. Fuel Change-over Valve P/N CBC4269 Can be found by removing trunk board to get to spare tire. (Diagram is for S3 so may be some differences in S2). Some have had luck cleaning insides with carb cleaner; if your tanks are full you are going to get a lot of gas spill, be prepared or as Doug would do, stick some pointed 1/2" wooden dowels into the hose as you pull it off valve nipple.
LT1 jaguar (05-20-2019)
My 87 would draw from whichever tank I selected but always sent the return to the right tank, never the left. It seems the electrical connections for the return valves in the rear wheel-wells were corroded. I fixed those connections and everything works properly now.
Rgds David
XJDanny
03-16-2019 05:04 PM
cbomb
09-14-2008 12:39 AM
