Fuel Tanks/ Caps?
I took my retaining strap apart temporarily 20 something years ago. Separated the halves and left them bolted on. Hood opens all the way to almost touch the bumper, it made the engine bay so accessible I never put the strap back together, and although I've not yet experienced a wind gust strong enough to be a problem, it is worth noting that the strap has a purpose. That said, fellow forum member here, @david84xj makes a nice kit to remedy this problem and is highly recommended.
https://www.jaguarforums.com/forum/market/218401/page2
yachtmanbuttson (05-08-2024)
Rgds
David
they’ll fit. Hang the tank by the single long vertical bolt, put the series 2 caps in place first without the o rings, then carefully shim and tweek the tank into position and tighten the three mounting bolts. May have to rinse and repeat a few times. Get the hoses in and clamps in place before final tightening of the tank bolts.
Retro
02-22-2012 12:10 PM
