Fuel Tanks Needed 1974 xj6
Thanks! I think I located a pair from an "86" I'm checking now to see if they'll match up.
I looked on this site www.spectrapremium.com and the pictures of new replacements looked the same. The first is "74"
http://prod.spectra-ssl.com/PROD/app...P_VERS=1.07.01
This might seem off thee wall but ALL of the jaguars I own have had rust in the tank do to a VERY poor design on the gas tank and the filler. To prevent water and other things getting into your tank from 69 and up use a 1985-87 xj6 filler and take off your old ones and REMEMBER always to replace that rubber seal that is ALWAYS the problem. The older jags 69-81 " all I own at the moment" have had the fillers to shallow and so when the drain line gets glogged you get water in your tank and you begin to rust around the filler and wheel wells. Easy fix here people you can even make the rubber gasket from Bath tubb rubber pads from home dept
FS[NorthEast]: Parting Out 89 xjs
kenatofc
10-27-2015 06:48 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
