gas tank flushing question
Old 08-29-2011, 09:25 PM
rinaldi63's Avatar
just saw your post and have cam across this same issue. if youve already received an answer elsewhere then disregard this. those plastic pieces are actually gauze filters at the bottom of the pick up tube inside the tank. these require a very patient hand in removing as they are on very tight and you do not want to break these. i used a long pair of needle nose pliers i bent with a torch to reach up inside and tap them down out of the plug. i also used a latex glove wrapped around them to reduce the risk of a spark while inside the gas tank. i would recommend changing them. or attempting cleaning them with a mild detergent and warm water. hope this helps.
Matthew Rinaldi
Rio Rancho NM
Just another newbie on the block
dsnyder586
04-04-2019 02:38 PM
GordoCatCar
01-02-2017 01:10 PM
XJsc-guy
11-23-2015 01:56 PM
hen555
09-07-2015 11:13 PM
alpecsa
09-07-2015 11:55 AM
Quick Reply: gas tank flushing question
