Gauge Dis-Assembly
Received 10,895 Likes
Cybersib (08-06-2012)
Don't be too worried. I've taken a few of these Smith's gauges apart and it went smoothly. The tabs are pretty thin material so they bend easily. Just bend them enough to slide the trim ring off. You don't want to fatigue the material and have one break, but again, it's not too bad. Once you do one, the others should be alot less nerve racking. Do the gauge that is the cheapest to replace first. That way if something does go wrong, you won't feel too bad.
Post pics as you restore.
Good luck,
Eric
Good luck,
Eric
X308XJR
05-20-2019 06:50 PM
