Gauge upgrade
Received 10,944 Likes
NOTHING worse than a Jaguar with a dashboard full of mismatched gauges from miscellaneous manufacturers .There are so many places to buy factory correct Jaguar replacement gauges (with their matching sending units)- why would you use something non Jaguar? Because they are pretty?
Received 2,399 Likes
Cameren:
Yup. SW and Jaguar are different languages. You need a match of sensor to guage.
Although, a couple ?) of years back, I lost faith in the Jag OP guage.. Little or noe showing!!!! well, the idiot light worked OK, and as m y car has hydraulic lifters, they were quike. So I need nt worry. but, I did.
I looked for a mechanical OP guage. No luck. So, I settled for an after market sun Pro, guage and sender. I plumbed it ina nd as I suspected, my OP was just fine.
What I did learn was the far mre robust sun Pro sensor had connection options> One made the numbers on the guage right on. Compatible.
but, I went back to a Jag sensor. A NOs via David Boger. Just fine.
Carl
Carl
Trick Freestones
XJ40 ( XJ81 )
34
01-24-2022 07:48 PM
Zulu4me
10-03-2017 06:55 AM
asleach2889
03-13-2016 09:07 PM
