GM 94amp Alternator
I do not see the connection between excess alternator out put and a failing battery???
but, I sure understand the word "electrickery" ! I did not coin the word, but admit to popularizing it!
So:
1. Swap in another battery and see if the 18v continues?
2. Check the battery. :Include a load test.
3. Warranty on the alternator?
Gee, Doug, I'm rationed to one cup of coffee....
Carl
So:
Carl
Bill, I would get that taken care of right away. We were at a car show and a guy with a modified 57 Chevy that had the battery in the trunk told me that his alternator went crazy and the battery either boiled over or exploded, I can't remember which. The result was battery acid all over his pristine trunk.
!. Some folks criticize John and his business plan. I am not one of them. I was always well treated. this is what I would have expected. The best advertising one can get in business. Stand by the product.
2. As I recall, John sells a part that adapts to the IL 6 to enable the Delco to bolt in. Hence, your comment as to a direct bolt in. I do recall a fellow on another forum doing so by subbing in the Delco for the air pump!
3. Somewhere or another, I have ajar of Delco alternator fix parts. I fixed one for my V* roadster.A deviation from it's all 40's theme. A frame, Flat head v8. T body and 35 Ford wire wheels... Oh, and a 32 B grill....
riemann
XJ40 ( XJ81 )
10-03-2008 10:05 PM
