Greetings and first request for help
Hi all, Graeme from New Zealand. Have just joined today, as I have a 1970 XJ6 Manual w. overdrive which hasn't been on the road for 15 years. My target is to get it roadworthy/restored this year.
At least that will stop my wife referring to 'Agatha' as a garden ornament.
This will be quite a journey, and I'm going to be asking for lots of advice. First up is if anyone iin NZ has a suitable wheel and tyre. Both Agatha's left front and spare are completely flat and I want any appropriately sized tyre (doesn't have to be road legal) and wheel so I can take the pressure off the fact she's leaning heavily to the left, of course.
Graeme.
![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
Graeme.
Accidentaljag (02-14-2016)
Received 9,204 Likes
But,
If you get new tyres now and they are fitted to a car which is going to sit in the one place for most of the year, you will only get flat spots and possible damage to the side walls.
At this stage you only want something to stop one end from drooping and a rig that is 'rolling stock' so that you can move it around the workshop space with relative ease.
The local tyre shop may have old rubber from a recent job which is 15 inch rim. Roadworthy doesn't matter until you actually get to the stage of taking the Cat on the road.
Cheers,
Nigel
Cheers,
Nigel
But,
Cheers,
Nigel
Cheers,
Nigel
Received 6,327 Likes
Hi o1xjr,
Commercial grade booties would suggest harder compound and therefore harsher ride characteristics perhaps?
Rears may not feel too bad, but fronts are where the 'feel' is.
I would be interested to know the outcome.
The Jaguar engineers did a lot of work marrying the suspension with the rubber back in the day.
Harder compounds would also wear harder on suspension components over the long term.
Cheaper now, not so later??
Cheers,
Nigel
Cheers,
Nigel
Slightly unrelated Graeme. You are going to need lots of bits and bobs. For the smaller essential bits like gaskets that you need new, I would suggest RenoJagVW http://www.rennojag.co.nz/ There is also a great guy in Taupo that does Jag parts. For second hand, I found that Ray at JagSpares in Upper Hutt was great. Not sure if he is still in business, as he was retiring and selling off his left over stock. Good Luck :-)
Thanks everyone, will stick some old rubber on an existing wheel. I think the spare wheel is clapped out like the tyres though. Another thing for replacement in the future.
And thanks Richard_gib for the info re sources of parts. I suspect this project may keep them in business for a while. But that's to be expected I think. Will be awesome when Agatha rejoins the road-going fleet.
Out if interest, does Agatha need to be re-vinned or is the rego on hold (live plates)?? Re-vinning will be a fair expense and it is very invasive to poor Aggie. For example they will want to see new brake disks, pads and maybe even calipers. They will remove all seats and lift the carpets looking for rust (suggest you look under the rear seat anyway, mine had a small swimming pool under hers when I had mine). If the plates are just on hold, it will be an easier process to get Aggie back on the road :-)
The following 2 users liked this post by Richard_gib:
Accidentaljag (02-14-2016),
o1xjr (02-13-2016)
Thankfully the rego is just on hold. One of the things I always check. I brought a Jensen Healey into NZ at the beginning of last year from the UK. Nice straight car in pretty good cond. Compliance took quite some time and $12,000. People had told me it was a pretty invasive check, but I thought they might mean a very vigourous WoF check, or even more like a Certificate of Fitness. But wow, had the car stripped down to the metal in areas to fix issues etc. So Agatha escapes the indignity of that. However as is so often the case, I look at her and go "well the engine needs a rebuild, and I need to replace the fuel tanks and exhaust, so maybe I should take the seats out at the same time, and if I'm doing that, maybe all the chrome off too.....". I just know I'll end up with her stripped right down. I don't think Agatha approves of stripping.
Great :-) Everyone has their own personal opinions and preferences, so here's mine. If Agatha was mine, I would fix the basics, get her going well enough, and in good enough shape, then get her road legal as soon as possible. Then you can drive her, fall even deeper in love with her, and then get the other stuff done. I have seen sooooo many 'project' cars getting forgotten, sold off or just never finished because of the passion wearing out, or the 'I'm never going to get this finished' feeling creeps in. If you are able to drive her, your passion will be with you for ever, and you will be even more inspired to restore her to her glory. I wasn't able to restore mine, and I had to let her go, and I don't want to see any of these wonderful girls get forgotten about or unused. Good luck, and keep us posted on your and Agatha's progress :-)
Accidentaljag (02-15-2016),
o1xjr (02-14-2016)
Do what you want ,when you want to it without the fun police getting involved. Makes owning old vehicles so much more enjoyable.
I have seen so many project cars go to waste because of lack of time, money or interest. Even the worst drivable classic is of more value to me than a project with no end in sight.
That kept my car laid up for an extra 6 months beyond the original plan!
Received 10,871 Likes
Too true.
Especially in cases where the owner has seriously underestimated the money and time he'll need to spend, and/or the car ended up needing more work than anticipated.
Or......
The owner disassembling far too much at one time and ending up with a seemingly insurmountable task of getting it all back together.
You need to plan ahead and stick to the plan....and to the budget
I have a project car in the works right now. To prevent the project from stalling out, even when I'm short on time, I work on the car several times a week....even if only for 30-45 minutes at a time.
There are the major aspects to a project....and then you have the seemingly countless smaller tasks. Those smaller tasks are great for keeping the project (and your interest) moving along. It might be as simple as degreasing some parts or re-taping a section of wiring loom....but bit-by-bit they all add to the desired end result.
I might not have time today to install my refinished dashboard....but I have to time to repaint and reinstall the washer bottle bracket. That type of thing.
Most importantly, these easy-to-finish tasks provide a sense of satisfaction and accomplishment ....which is needed to keep enthusiasm up.
The following 2 users liked this post by Doug:
o1xjr (02-15-2016)
