hazard switch
Received 9,244 Likes
Elinor, I have found that lowering the steering column (without removing the bolts entirely), eases the job of removing the upper nacelle. All you need is about 1" inch of lowering.
If you don't lower the column, either the nacelle breaks, or the hazard switch breaks.
Also I added a strip of stick-on brown Felt (sold at Joann's Fabrics), to the wood dash "n" area above the nacelle, to prevent the rubbing of plastic and wood. It also finishes the area nicely.
The latter is no sin, but the former is inexcusable.
I had fun fumbling with those spacers myself. I had 5 of them - I think 3 on the right and 2 on the left. I ended up taping them together so at least they weren't falling all over the place but I like the super glue idea.
Not quite sure what their purpose is as far as leveling or balancing or whatever it is they do.
#30
Nanonevol (02-28-2018)
#31
as it turns out the old Hazard Switch I found complete with its wiring connected is a Series 2 switch, based on the silver decals on the wipers stalk switch. I'm going to repair the broken-off pin "ears" with washers.
Nanonevol: did your new switch come with a Triangle ("hazard") symbol in white paint that can be seen from the driving position?
#34
thank to you guys i found my hazard switch.
it works but normally only the left signal turns on when hazard is on.
To have both 4 signals working I have to switch the hazard on and also engage the right signal lever. in this way it works.
There is something wrong but... not really willing to deal with this now.
#35
