Hazard Switch (1985 Jaguar XJ6)
I just finished a "driver restoration" on my 85 XJ6VP!
One last job, I replaced the hazard switch with one from a 1987 XJ6 (which was a pain in the xxxx to do)! Everything is working perfectly EXCEPT the turn signals work with the car off, and the hazards work only when the ignition switch is on!
I have reviewed this old link. I feel there are 2 wires that need to be switched? Can anyone help?
https://www.jag-lovers.org/lumps/tec...als/haz_sw.htm
Help much appreciated!
Richard
r
Richard
r
Those old schematics and write-ups were from Charlie Nowlin; very interesting and nice guy. About 25 years ago I reckon
Anyhow, swap the two wires that carry power to the hazard switch. In Charlie's schematics they'd be the green/blue and brown/orange. In the Jaguar schematics the green/blue is shown as green or light green; solid color.
SOLVED!
I used the following wiring diagram to realize I had to switch the "green" and "brown/orange" wires. Now, the hazards come on with the ignition off;turn signals with ignition on! It is the best wiring diagram I found! I am attaching pics of the switch with the referenced numbered connectors! Hope this clarifies some confusion!
Thanks Doug (DD) for your help!
Richard
Terminal 1 - Light Green/Blue stripe
Terminal 2 - Dark Green/White stripe
Terminal 3 - Light Green/RED stripe
Terminal 4 - Dark Green/Light Green stripe
Terminal 5 - (nothing)
Terminal 6 - Light Green/Pink stripe
Terminal 7 - Dark Green
Terminal 8 - Brown/Orange stripe
Richard
The following 3 users liked this post by benzjag:
Eurowerks
01-05-2015 11:34 AM
