Head lining replacement
Hi all,
Can anyone recommend any good articles or videos showing replacement of a sagging head lining on my Series II Daimler?
I don't suppose there is anyway to glue up an existing sagged lining?
I have come across some excellent Utubes called Living with a Classic that provides concise and comprehensive information on performing many tasks on the V12 but I haven't seen one on head linings.
Any information greatly received
Al
Al
I have an article in an old Jaguar Driver's Club magazine that covers it well.
It is almost impossible to do this job in place unless you are some sort of Wizard with glue and material.
Best done by removing the rear window (backlight in Jaguar parlance) and so removing the hard roof liner. I have done the job twice in 36 years and may need to do it again soon.
I will see if I can find this article.
The following 3 users liked this post by The Mekon:
in the Series 3, the headliner fiberglass pad will come out through the rear door, no need to remove the rear glass. Unless of course the Daimler is different. The fiberglass pad is flexible enough to bend slightly without cracking.
you first remove the front and rear seats, then all the trim, sunvisors, rear view mirror, etc., on the sides, front and reat.
the pad is held by brackets on each side,
remove those brackets and the pad falls on your head.
pull pad through one of the rear doors at the angle it likes.
Lay it flat and pull the old fabric, scrape pad with a brush to remove foam dust.
Spray headliner adhesive front to rear, side to side, and angularly.
lay fabric on the pad and roll to end using a lightweight paint roller. Do not press material hard, just let it find its shape.
The following 3 users liked this post by Jose:
[QUOTE=Jose;2144632]in the Series 3, the headliner fiberglass pad will come out through the rear door, no need to remove the rear glass. Unless of course the Daimler is different. The fiberglass pad is flexible enough to bend slightly without cracking.
Yes, the article I posted was about doing the job on a Series 1. On a later LWB car it may be possible to remove the liner via the larger aperture rear door. Another option is to remove the seats and drop the liner on its side to glue up. So I believe there may be ways to do the job without removing the rear window.
Hi all,
several years ago my wife and I did the headlining of our P38 Range Rover (1997). It came out the back tailgate which made life easy though it did have a sunroof which the Daimler does not that added to the complexity.
It was a big job but never overwhelming. The results were superb. Having a hanger to work in with unlimited room certainly helped.
After a lifetime of mucking about with (British) cars the one area I have yet to venture into is the removal and replacement of windscreens, I would be very happy to remain in the dark about performing this task. Some say it's no big deal but I suspect different. I will be very pleased if I can get the roof 'biscuit out the rear door.
regards
Al
regards
Al
Hi,
Great information from Jose and others in this thread! (no need to post my question..)
I`ve just bougt an XJ6 -81 and included was a brand new head lining.
Now I soon will try to change it through the back door, and it feels great to avoid removing the front or rear windows... (I belive there is some hidden rust under the finish-up paint..)
Regards
Martin
Regards
Martin
Jag Headlinings - I think they also have a couple of youtube "How To's". Nice thing is they replace the fiberglass with a flexible plastic backing - roll it up and it "springs" flat inside the car without needing to remove as much.
I was in contact with them I think in 2020 and they wanted 400gbp to ship to Canada ($500+) and would only accept payment by bank transfer. Maybe things have changed, especially on the shipping charges? Bonus was they'd be able to fit two into one box, for those of us with two droopy Jags or a friend in need.
and how much was the cost of the liner itself in 2020 ?
seems like too much money. I would invest in the fabric, (from BAS Ltd.), the adhesive, (Autozone), and do it locally.
I did mine myself with my girlfriend and it was not such a difficult job, just a lot of dismantling, because I removed all the seats and laid a plastic cover on the floor to work comfortably and protect the carpeting.
In the Series 3 XJ, The liner pad will come out through the rear door without breaking.
yachtmanbuttson (08-15-2023)
Agree with Jose. I did this job by myself with Headliner Fabric from Joanne Fabrics. The color isn't perfect, but close enough if you don't care about car shows. My backer kinked a tiny bit but did not break and I was able to reinforce it and put back in. Been there two + years without any problem. Pretty cheap fix if you don't mind putting in the time and elbow grease. IIRC there are some step by step DIY instructions out there.
Here's a link to a thorough description of replacing an S3 headliner.
https://www.jag-lovers.org/xjlovers/xjfaq/headliner.htm
yes, it is very muggy too. Use 3M Headliner adhesive spray. Follow the instructions.
The fabric should be laid on the pad at the center by two people, one on each side of the pad, then spread towards the outside using a new paint roller, letting the paint roller's weight do the job. If you press with your hand, it will leave an indent.
I ordered my fabric from BAS Jaguar Interiors, it has held for over 15 years now. Unfortunately my local Joann Fabrics discontinued their headlining materials.
yachtmanbuttson (08-17-2023)
