Help! 95 Jag XJ6 VP/XJ6
If you can't get into the trunk, you could try to connect the charger's positive lead to the the positive connecter on the starter. Usually these are the thickest cables in the entire engine bay.
Then connect the negative to a good ground. Slowly charge the battery, no more than 10amps....should do the trick...
cat_as_trophy
Australia - Queensland
10-14-2016 01:58 AM
FS[Western US]: XJ6 SBC conversion parts
gboy
10-14-2016 12:34 AM
Dion Baker
10-12-2016 05:11 PM
