Help with fuse issue?
Received 10,871 Likes
Does a new fuse blow *instantly* ?
Is there one particular accessory that always blows the fuse? Or combination of accessories?
Do you have a wiring diagram?
One method is to determine exactly what's on that fuse and systematically start disconnecting sub-circuits until the fuse no long blows
In that case it has to be an item that is permanently powered.
Possibles are: Ignition Switch, Interior Lights, Clock, Door Locking, Hazard Switch, Light Switch, Footbrake light switch., Radio.
I do not have a diagram for your vehicle but if you can see the fuse on the diagram then follow the lines to the items that it powers.
Roger
Roger
sayitaintso
05-25-2016 09:32 AM
