Help with running lights
I been working on this car for some time and getting close. Now I'm working on lights and I have all the running lights working but the right rear. I have nothing no running or brakes break lights, not even the side marker light. It is almost like the harness isn't plugged in but, I can't find anywhere that it plugs in. All the fuses are fine. Some thoughts would be great. Thanks
Tom
Tom
Received 10,871 Likes
As the running lights and brake lights are two separate circuits you *might* have two different poblems.
Or in fact there might be a harness connector problem as you say. I can't remember the location of the connectors off hand. I'll try to get that info and post back
To clarify the fuses issue: are you aware of, and did you check, the fuses on the forward bulkhead in the trunk?
