Help XJ6 Starting and Idling problem
I have an 85 XJ6, that was running fine, then one morning I started, and got misfire, and would not startup. I managed to start by cranking few time, with the gas pedal on. But soon as I drop below 2500 rpm the car stumbles and dies. Even when I have the gas pedal pressed, I can not lower gradually to say 1500 rpm, just drops from 3K down 500 or so, then dies.
I assume the fuel pump must be ok, since I can keep it started over over 3K rpm. I had changed the fuel filter a year ago or so.
Can relays, fuel regulator, AFM or fuel blockage contribute to this type of problem.
Guidance is much appreciated.
-Kadeer
85 XJ6
2004 XJR
-Kadeer
85 XJ6
2004 XJR
Received 10,872 Likes
Try the same experiment but turn the key to 'start'. The pump should run. If not, post back
Check the duct from the Air Flow Meter to the Throttle Body. Is it secure? No holes or rips?
no holes or rip to the throttle body.
Doug, I turned the key to the 2nd position, without starting it, no power to the pump. I read if you put it in Drive, and put turn the key 2nd position, the pump should activate. No voltage on the wire.
Is it possible, that because my car has a 3/4 full tank of gas, that the fuel is flowing to the rails without the pump running, I am parked on a slight incline down.
Doug, just went out to try your suggestions. Thank you for your guidance. I turned the key to position 3, start, and the pump was working. I also verified with jumping the fuel relay, 30&87.
Then I rechecked the throttle body lines, turns out the clamp of the throttle body was loose, and pipe was not fully in from the AFM. Soon as I put it in place, everything went back to normal. Starts and idle fine now.
Surprised to see how erratic the car was with partly unmetered air.
Thanks again.
-Kadeer
Thanks again.
-Kadeer
Doug (09-30-2021)
Received 2,399 Likes
James Zimmerman
09-03-2017 04:07 PM
