Hernia
Received 9,262 Likes
When I let Nix have her head last night she strained something. There was a rude noise coming from under the hood and as I rounded the corner to the driveway, and a belt squalling, and I noticed the headlights were strangely yellow. Odd, I thought, they were fine a couple miles ago. When I got into the house husband mentioned they seemed a little yellow to him too.
I think Nix herniated that 1986 alternator (I'm sure it's original with the conversion)! It's OK though, husband is says he has another one stashed somewhere. It will doubtless be changed over the weekend.
While we're at it, I'll track down that brake fluid leak and fix the speedo cable.
Received 3,959 Likes
LnrB (09-24-2015)
Received 2,399 Likes
Perhaps a bit of diagnostics before swapping out what might be a perfectly good alternator.
1. What else does the belt drive? AC pump, Ps pump, water pump, air pump?
If one or more of those are going tight, rpm for the alternator will drop and
so will out put.
2. Bad belt/s?
3. Test the alternator in situ. A stethoscope or rough substitute for noise
indicating mechanical failure.
4. The VOM to test for out put. I'd use my patch cord if it were my car doing that.
5. Rough test. Lights on. Dark is best. Rev the engine. Lights stay yellow or get brighter?
6. Not the alternator at all, a failing battery....
But, that is what shake down cruises are for.
Looking good, running good, not bad at all.
Carl
so will out put.
2. Bad belt/s?
Carl
LnrB (09-24-2015)
