High beam
Do you hear the relay click when you operate the stalk? If so, then the relay is working but I suspect the latching mechanism is broken inside the relay.
If you don't hear a click.....
Remove the blue/black wire from the relay. Use another wire to ground the now-vacant terminal. If the relay now operates then your stalk switch isn't completing the ground circuit
LnrB (09-19-2020)
Go to this thread and look at post #6. It's shows the ground tab at the base of the stalk and the blue/black wire. You should see the same or similar (I've seen a couple different style tabs) and fixed them just by cleaning them.
https://www.jaguarforums.com/forum/x...f-time-234078/
You'll have to remove the column shrouds to see this. Or at least the lower one. Be careful when handling them; they're fragile. And don't over-tighten the screws on reassembly
Your probably seeing the capacitor, which is covered in red insulation.
Proceed as planned
Also, is there a trick to getting the top half of the steering wheel shroud off to get a better look at the contacts? Thanks, Joe
Once you have the bottom shroud off look underneath and you'll see one or two screws that hold the upper shroud to a metal bracket. Remove those screws and wriggle the shroud away.
If the shroud doesn't want to come away, don't force it. Lower the steering column a bit. This is very easy. Remove the under-dash trim panel and loosen (don't remove) the two large-ish nuts that support the steering column. This allows the entire column to drop down a bit.
