High Beam Help Please!
Have an 85 XJ6 Vanden Plas. Recently my high beams started acting up and wouldnt engage right away, would have to keep flicking it until it came on, and would be a B**** to turn off. Right now they wont turn on. I have no idea what i could do to fix it. Help please?
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Might be a bad headlight relay. The relay is a silver box mounted on the left front inner fender.
Read this checklist: http://www.jag-lovers.org/newbies/se...s_iii_xj6.html
Click here for diagrams
Click here for more diagrams
Good luck!
Good luck!
johnwus83 (07-29-2016)
Reading it over again today, if you have to fiddle with the switch that much, it might well be the switch itself. The contacts may be dirty inside the switch.
Also, found some more info about things that can go wrong inside the relay:
http://www.jag-lovers.org/lumps/tech...s/relays2b.htm
Received 10,933 Likes
CHECK your ballast and all wires? maybe it is cuz some of wires are loose
you can fix you ballast by relay harness so it can work steadily.
http://www.vvme.com/hid-relay-harnesses-c-20.html
A headlamp ballast? On a 80s vintage Jag? No.
Do you mean the black plastic shrouds/covers? If so.....
There are three external screws to remove to lower cover. Once that's off, lokk *inside* the upper cover and you'll see two or three more holding the upper cover to the bracketry of the switches. Once all the screws are removed it's best to lower the column a bit to ease the job of wriggling the upper cover out. To lower the column simply loosen (don't remove) the two big nuts on the column bracket....you'll see 'em.
If you look closely at the dimmer switch you'll see a thin spring metal blade that completes a ground circuit when the lever is pulled back. Hard to explain but you'll see it. Anyhow, give it a few squirts of electrical contact cleaner.
I've fixed a couple of wonked-out high beams circuits this way.
I have a similar problem in that sometimes only the high beams will work, and when I use the stick to flick back to low beams there is no beams. I'll flick the stick back and forth numerous times and about the time I'm getting a little strobe sick the low beams will come on. Thanks Doug for steering column info, I'll have to do this too. Have one other problem (horn) also in steering column... another post.
I think ellen/victorking is talking about a HID conversion kit that your car does not have. It is a good idea to check for loose connections, that is basic. Make sure all bullet connectors are fitting tight, and use a wire brush to clean them when they are disconnected so the contact surfaces are nice metal on metal with no corrosion. Also, it is good to add a little dielectric grease to the terminals to protect them from oxidation. This applies to the headlamp bulb connection as well.
Once you take apart the column and the switch, it is pretty easy to see the contact surfaces and renew them by using something mildly abrasive to make the metal shiny again, use a bit of dielectric grease here too.
The HID person seems to think that we are talking about HID conversion, but I believe the people asking for help all have stock headlight systems.
There are now a couple of posters who have been removed from this thread. Thanks for your vigilance guys, we rely on everyone to help keep this forum clean.
If you have a doubt about a potential spammer use the report button and we will look closely.
Thanks again.
I wonder if the OP ever got things sorted?
Thanks again.
Hi John
You may not have noticed but the thread was 6 years old, you will be lucky if the OP resurfaces after all that time.
What is your problem? no high beam? if no high beam please check if they work when you flash the headlights with the headlights off (daytime flash).
Let us know and we can help step you through finding it.
Just some basics about the headlight system:
The high beam/low beam switch does nothing more than send a short duration earth pulse to the headlight relay. All switching of power is done at the relay (power via the rotary dash switch for low beam, from hard wired sources for high beam). If you operate the lever and hear the relay clicking your problem is in the engine bay.
High beam and low beam are fused separately
Headlight fuse panel is notorious for poor connections. A good starting point is to remove all fuses, check them with a multimeter (they often can look good but be blown), clean the fuse retainers and add a little inward tension on them, clean or replace the fuses before reinstallation.
Another common problem is the earths near the headlights. They are also a candidate for cleaning up.
johnwus83 (07-26-2016)
Received 2,399 Likes
One of my first lessons in Jaguar electrics was replacing the right out board seal beam when it went dark. Normaly works in other critters. Not here!!
Agree on the fuse and fuse box cleanup and electrical continuity verification. I removed mine from it's cage and cleaned the contacts behind. Grungy is an understatement. Much better response to lighting commands. At times they had been random combinations!!!
Side tracked on dash light fix. Band saw blade parted. I've new ones
but resist staying on the drive and idle wheels. Location n ot ultimate.... access limited...
Installed a CO detector and serviced the smoke detector. Simple tasks no longer simple... But, tested and done....
Carl
Carl
