Horn doesn't work
Horn doesn't work
Good morning, the horn sometimes works sometimes not, I disassembled the link that goes from the button to the inside of the steering column and I saw that it is no longer welded at the bottom.
Which is the best solution? Do I have to pull off the whole steering column?
Car: Jaguar XJ6 4.2 series 2
Thank you
all!
Thank you
all!
yes exactly. You might not even need to solder it back, just close or tighten the ring where the rod enters the copper tab so that it goes back in very tight. You might be able to do this with L shaped needlenose pliers.
In my '84, I can see two cutouts or "windows" in the outer column where I can see the inner column. One of the copper tabs contacts the inner column. I believe the first copper tab on the way down to the firewall is where the rod fits into.
TheEssential (12-13-2018)
My records show the thin rod (which is called a spear) fits into one of the rings in the copper tab and when the threaded horn shaft is installed the spear enters the plastic portion of the threaded shaft. No Pics.
I have been trying to upload pics for some time now to no avail.
I find and open the pic I want to upload, it goes to 100%. I then click on upload and nothing happens. This has been going on since the new format was introduced.
I have asked for help on this but NO RESPONSE!!!!!
Sanchez, que pasa?
do you have a Photo Editor?
check the size of the image in pixels.
if the image exceeds the allowed bits it gets rejected.
I take pictures with a digital camera or phone and they are too big, something like 2500 x 1326 pixels. That is a lot of megabytes.
so I take them to my Photo Editor and resize them to 800 or 900 pixels.
They upload fine.
They upload fine.
blueoakleyz
03-29-2019 03:49 AM
harryf
07-09-2015 04:43 PM
Bostoncamaro
02-03-2012 01:49 PM
