How do i get more front negative camber
someplace on THIS forum, there is a guy building an XJ Jaguar for drifting, he is also doing the 6 cylinder turbocharged!
he is up around Seattle NW area, he has a lot of good ideas for XJs.
in fact if the XJ engine dont make it he was going to use a Toyota 2JZ engine.
30 pounds of boost, and Schneider reground cams and springs
Exactly what the title states how do i get more negative front camber? Im also playing with the idea of making some tubular lower control arms to poke the front wheels out more and get more steering angle.
(bonus points to any one that knows why i want more angle in the front
![Icon Naughty](https://www.jaguarforums.com/forum/images/smilies/icon_naughty.gif)
You don’t even have to open it up (assuming it’s OK ) Just put a decent sized turbo on it ( T6 or bigger) use E85 in the US or pure alcohol in England. And a pair of reground camshafts
Turbo’s are surprisingly cheap. E bay or Amazon frequently have them for a few hundred dollars. Plenty of how too’s on U tube.
Typically they show the Chevy/GMC trailblazer or Envoy engine. Which requires more work and aren’t as well built.
Yes you will need aftermarket ECM like Megasquirt and a lap top computer to tune it ( old one is fine).
Let me dispel a few myths. Used high mileage engines will wear the rings to the needed .020 end gap size required. Stock Cast pistons are OK. it’s too tight end gaps that cause piston failure and with alcohol .020 is enough. Alcohol burns cooler than gasoline. Stock gaskets are good up to at least 30 psi. If alcohol is burned.
You will need bigger injectors you can spend big money for aftermarket ones or adapt others.
ronbros (04-03-2022)
