How To :: SIII VDP Seat repair
Thought I would post this so others see that even an idiot can fix his seat !
This is what the drivers side bolster on my XJ6 looked like.
![](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/59456-how-siii-vdp-seat-repair-sarc-4188-albums-posts-2-7409-picture-20131019-145322-21157.jpg?dateline=1382413166)
It detracted from the rest of the otherwise very good interior. I have used products from LeatherMagic before, so I bought the kit with the factory doeskin colourant.
First step is to place spare materials underneath the leather and glue it in to place
![](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/59457-how-siii-vdp-seat-repair-sarc-4188-albums-posts-2-7409-picture-20131019-150707-21158.jpg?dateline=1382413166)
Then you cut out leather patches to fill the holes. The leather patches are glued down to the material you added in the first step
![](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/59458-how-siii-vdp-seat-repair-sarc-4188-albums-posts-2-7409-picture-20131019-153203-21159.jpg?dateline=1382413166)
Then you apply the rubberised repair compound over the top...... this is the bit that takes some time and patience to get right. Basically you need to apply a coat, then sand it back, then apply another coat, etc until its really smooth
![](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/59459-how-siii-vdp-seat-repair-sarc-4188-albums-posts-2-7409-picture-20131019-154045-21160.jpg?dateline=1382413166)
Then you start to apply the colourant. After one coat it doesn't look good and you are thinking to yourself "What have I done"
![](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/59460-how-siii-vdp-seat-repair-sarc-4188-albums-posts-2-7409-picture-20131020-134354-21161.jpg?dateline=1382413166)
But after a few coats, it looks pretty good.
![](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/59461-how-siii-vdp-seat-repair-sarc-4188-albums-posts-2-7409-picture-20131021-200854-21162.jpg?dateline=1382413166)
Not perfect, but a whole lot better than it looked before.
I've had it last for years on previous jobs I used it for. Interestingly on one job, the area I had repaired remained intact even when the surrounding leather started to fail. I think the key is to not use the car or stress the repair for 3 or 4 days if you can. This allows the repair and colourant to really set properly
Received 10,862 Likes
Received 2,399 Likes
Here you go..... Deluxe Leather Repair & Restoration Kit | Furniture & Car Seat Repair kit
It was like that from the PO. It's the usual place where, if you are a little bit on the portly side, your rear end rubs the seat on the way in :-)
Rhett (10-19-2014)
aholbro1
08-05-2021 05:02 AM
