Idle adjustments...
Idle adjustments...
Cold start idles high at 1800 rpm, semi warm the needle bounces between 500-700, fully warm it idles at about 700, engine rattles a bit when shut off, feels like its retarded without the fuel. I've got the idle adjuster screws all the way closed, so something must be off....timing? carbs?
Received 10,892 Likes
What kind of Jag is this, specifically?
I'm still learning the details of these cars, but my first guess on the idle is leaking vacuum lines somewhere around the intake.
The rattling noise I'd guess is telling you the timing chains need adjusting. Mine did when I first got my car (Ser III XJ6). After that it quieted right down.
Good luck.
Good luck.
What carbs are fitted, SUs or Strombergs ? By now, (i.e. over 30 years since the car was made), there is likely to be some wear in needles and jets, so best to get a rebuild kit and clean and rebuild the carbs so you know where you are starting from. Cellulose thinners is ideal for cleaning off petrol deposits and gum.
