Idle speed adjustmet
I can get my 1981 XJ6 to idle correctly and run good by adjusting the timing. If I use the idle speed adjustment screw it has no effect. If I screw it in all the way or out it does nothing. I have take the idle adjustment off and cleaned it out and it look good. How does it work and what is the purpose of the over-run valve. thanks for any input...Jerry
Received 10,920 Likes
