Idle UP when AC ON at idle
Has anyone come up with a way to boost the idle speed when the AC compressor is engaged and the car is at idle? I'm thinking a solenoid operated valve bleeding extra air past the butterfly could work. It would need an adjustable metered orifice to set the increase and would be powered via a feed from the compressor clutch circuit via a micro-switch on the butterfly valve. An air source after the air filter is feasible but I'm not sure where to bleed it into the manifold.
I'm always a bit nervous sitting at a stoplight with the car in gear and the AC on when the idle drops to 500rpm. I'm also not comfortable with a normal warmed idle speed (AC off trans in neutral) above 850, which is what mine is set to. Put it in gear and it drops to 700, turn AC on and it goes to 500.
Any thoughts?
Any thoughts?
Received 10,989 Likes
Jaguar offered a retro-fit, all-in-one kit for this exact purpose. I'll see if I still have the documents....which may be of some interest to you. But, anyway, the essence of the modification was just as you've described. The heart of the modification was an extra air valve to admit .....extra air. As I recall the valve was the same part number as used on many V12s for the same purpose.
More later
More later
The following 2 users liked this post by Doug:
Greg in France (08-11-2020),
Jag7651 (08-11-2020)
I couldn't readily find my documents but....we got lucky!
I found this collection of Jag TSBs on line
Click the link. Scroll about 2/3 way down. Your looking for bulletin JD 08/84 Item 65
https://www.terrysjag.com/XJS%203.6%...e%20Engine.pdf
The amount of RPM drop you're getting with compressor engaged.....200 rpm.....is more than typical. I'd say 75-100 rpm should normally be expected.
The Series III 4.2 was slightly notorious for "Unstable/weak idle" issues; some worse than others for no apparent reason that I've ever determined....and others apparently not affected at all. Some just seem to have a problem sustaining life at idle speeds. Ever increasing age with corresponding slight and gradual degradation of all involved systems might play a part.
Many many years ago, when more of these cars were still in regular use, the topic came up more often.
I recall fattening the idle mixture on a couple cars and that seemed to help reduce the excessive rpm drop.....and give a smoother idle as well.
Or, just do some experimenting in both directions, maybe a quarter turn at a time....waiting a minute or so between adjustments to give the system a little time to stabilize. Ideally you'll feel the idle get a little faster and/or a little smoother....which means the engine likes what you are doing If the idle ends up being too high as a result of this you can then go back to the regular idle speed adjustment screw and back it down a bit
MK2
05-12-2016 04:44 PM
