Ignition and air pump harness
Heck, I'd be tempted to just make new ones myself even if they ARE avaiable for purchase. They're pretty simple looms....plus you could use a higher grade sheathing and/or devise some re-routing to prevent heat damage in the future.
Anyhow....
I'm 99% sure that a couple outfits make a *fuel injection* harness for your car ($500 or so) but I'm not aware of anyone making any other looms for it.
Others will chime in
Anyhow....
The good news is that the fuel inj. harness can be had for less than 500 -- contact the vendors directly (Welsh, etc.). I think mine was at most 350.
Check into shifting it up and away from the engine when you install -- try simply turning the retainers backward from their current installation. Air flow should keep the heat away.
The air pump harness you'll have to do yourself. Believe me I looked, but there's apparently none to be had. Just get some 5/8 heatshrink and build your own.
Engine harness is like 80-150 USD, variable.
Guy-Pierre Boucher
09-16-2015 05:55 PM
1964Daimler
09-09-2015 11:28 AM
