Ignition Click
Brown to white red is basically doing what the relay is supposed to do, get battery to the solenoid. If you are hearing the relay operate when you turn the key then the wiring to the relay coil seems to be OK. Sounds like a faulty relay. If so you have 3 options: open it up and clean the contacts, just replace it with the standard unit or swap over to a current generic relay.
An article about the last option is here.
Jaguar Specialties
Jaguar Specialties
Received 2,399 Likes
Yeah, my OEM tin can relay left the engine bay a decade or so ago. I installed a generic Bosche type 40 amp relay and it has done just fine.
Some say the tin cans can be opened, the point cleaned and returned to service !
But, why?
I have one of the generic ones that has a melted side. Inside is a miniature version of what is in the tin one. Slick.
Carl
But, why?
Carl
You have proved the wiring from the solenoid back to 12v + via the jump wire. From your description you still get the relay click when you turn the key, so that suggests that the earth that comes from the transmission selector is reaching the relay, otherwise it wouldnt react to the key at all.
I guess next step might be to get a multimeter and check that you have solid earth and 12v on the relay coil and its not just partially activating. The other possibility is that you have two dud relays unless the second one is known good or new.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
gunlocators
09-30-2015 08:05 AM
