Ignition relay Jaguar XJ6 4.2 series 1 1973?
Hello,
I need help!
Suddenly, Wipers, heater fans, flashers and stop lights are not working. I have checked the fuse number 3 and is ok, The problem is that there is no electric current at the fuse terminal.
I have looked at the wiring diagram and it seems that current comes from an ignition protection relay.
Does anyone know where and how is that relay? any other possible suggestions for problem solving?
Best Regards
I need help!
Best Regards
You have now found out that the location of the various relays was a well kept Jaguar secret.. along with the location of the poor quality push together
plugs...
Probably just a bad connection on one of the wires... new relays are readily available.. gotta love Lucas.
plugs...
I have forgotten what the purpose of the one on the left side is?
Jaguar hid a lot of the required items.. while in there with the dash pad off... find your AC expansion valve that is buried almost underneath the Ignition relay...I attached a photo of it for your reference.
sanchez
04-17-2016 07:42 PM
