Ignition Wire Group
Ignition Wire Group
Caping some plastic bezels back on around the steering wheel, fairly sure the ignition purple/black wire has a ready made partner in the purple/black of the ignition wire bundle but i have a single loose black wire hanging but going no place. i also have a few loose wires in the foot well at right which i think are related to the door open/close triggers but not certain. Any thoughts?
the purple from the ignition seems to have a ready partner in another purple/black plug beside it but I also have a loose black one ...?
These guys drop down from beside the fan near the foot pedals without clear ID. related to door open/close maybe
adenshillito (08-14-2021)
Grant Francis (08-14-2021)
That copper critter is the connection for the horn. Can’t remember if it’s the earth or the black/purple.(fairly sure a male bullet connector on a black wire pushed into it.
One black and purple wire is for the horn, the other is redundant on your car. It is for the headlight buzzer in the USA market.
If you have a Haines manual check out the US wiring diagram.
adenshillito (08-17-2021)
And... speaking from experience - it needs to be cleaned periodically and apply a dab of dielectric grease with a Q tip. I only see one in the pic above; my 1975 XJ6C has two of them. Both of them accessable by just taking the upper knee scuttle off. I stick a blue shop rag into the hole and rotate the steering wheel to clean all the way around the "armature" hub part. And be careful to also clean the copper (or brass) "brush". You can see in the above pic this one is due.
Symptoms - horn starts going off intermittently when driving (very annoying and embarrassing - it may illicit the one-finger salute from other drivers that think you are honking at them for their self-perceived excellent driving). And... the steering column starts making this weird "scratching/rubbing" sound that drives you crazy.
sempaipaul
01-14-2007 02:25 PM
