Ignition wire routing and OE clips
My ignition wires are like twisted spaghetti over top of the engine. I would like to properly route them using OE or aftermarket clips to avoid any ignition crossover.
Does anyone have a diagram or even a picture of how these were routed from the factory? Are OE clips available still or is aftermarket the best option at this point?
Received 10,891 Likes
Whow, Doug ! Is that your car ? It looks to be absolute perfection !
For those that cannot see, the ign. lead clips look like combs with the leads slotting between each gap in the "teeth". As I remember there are two or is it three, each one shorter than the previous one as the leads go off to each plug
jagent
09-12-2015 01:40 AM
