Injector relay
Received 10,980 Likes
Does this occur only when hot? Only when cold? Any particulars?
My start relay has started chattering on start up.
Possibilities: Low voltage, poor connections, dirty contacts inside the relay
Sometimes it starts when I can hear the injectors working.
Not quite sure what you mean here
It motors over well. Why are my injectors intermittant
If you sure that the injectors are intermittent check the connections at the 'main' relay and the injectors ballast---which is mounted on the RH inner fender, well forward and down low. Also check the bundle of ground wires at the rear of the water rail
philc850
62
06-28-2016 10:37 AM
Nee_the_Bogeyman
04-03-2016 10:41 PM
