Installing a aj16 into XJ6 coupe help.
Old 07-03-2020 | 09:07 PM
jag Simon's Avatar
Default Installing a aj16 into XJ6 coupe help.
Hello I am a new member who lives in California and I have owned and restored a few Jags over the years. My son and I have started a XJ6 coupe resto and we have decided to put a later model AJ16 drivetrain in it as it is currently without an engine. We purchased a running but totaled 1996 Jaguar XJ6 as a donor vehicle and we are in the process of stripping it down. I have successfully rewired a few cars over the years but I am finding the wiring on the 1996 XJ6 a little intimidating. My first question of many more to come is about the factory security system. What must I do to bypass it without causing problems or is it as easy as just removing the module? Thanks.
Old 07-04-2020 | 12:18 PM
JagCad's Avatar
Can not say with specifity. Not familiar with the 96 car. Saw a beauty at the gas station the other day..
1. Check the list here for the 96, and seek an answer as to the security system.
2. Get the wire schematic for the 96, study the logic of the module and how to defeat it.
3.Check with Andrew at jaguar specialties. He sponsors and post here His swaps are to GM power, but has encountered that security system for sure...
What a slick project...
I and others will follow if you post progresss..
Carl
The following 2 users liked this post by JagCad:
jag Simon (07-04-2020), Mkii250 (07-05-2020)
Old 07-04-2020 | 12:36 PM
Yellow series3's Avatar
I hate to be a party-pooper but I think your going to find the sump interferes with the front crossmember. In the Jaguar Journal a few issues back there was a 3-part article on how they cut and welded a big chunk out of the front crossmember to fit your engine into a coupe. You can find the past issues available for free down load Here.
I full understand your desire to keep the car all Jaguar. But it is going to be a ton of work whereas there are proven kits available to quickly and easily install a GM small block. Or, of course, you can easily get a used replacement XJ6 Series III 4.2 engine and keep the car original from David at Everydayxj.com
Jeff
Old 07-04-2020 | 03:00 PM
Jose's Avatar
why not ask in the X300 Forum? You are dealing with a totally different engine and electronic-digital systems than in the Series 1, 2, and 3 XJ-6.
yes your car's body is a 1970's XJ, whether Coupe or Sedan, but trying to transplant a 1990's engine and electronics will be hell.
Old 07-04-2020 | 05:47 PM
jag Simon's Avatar
The reason I am an this Forum is because I know that other people have done this in the past with series 2 coupes and sedans and I was hoping to reach out to them. Thanks.
Old 07-04-2020 | 05:51 PM
jag Simon's Avatar
They ran the AJ16 engine in the XJS from the early to mid 90s and the XJS uses the same front cross member as the series 1,2 and 3 XJ6 ,or so I thought. Maybe I am wrong.
Old 07-04-2020 | 06:15 PM
Doug's Avatar
Over the years there have been a number of successful swaps with the AJ6 going into a Series I-II-III car. There's no reason I know of that the AJ16 can't work if you slog thru the additional electronics.
The security system on USA market X300s didn't used a 'chipped' key, so there's one less thing to worry about. I can't remember many details about the security system although I drove an X300 for years. I don't think it had any "immobilzer" capability at all. I recall that is was simply a burglar alarm, so to speak.
I can't answer your specific question, sorry.
jag Simon (07-05-2020)
Old 07-04-2020 | 07:19 PM
Larry Louton's Avatar
Default It fits, It fits, It fits.
You need motor mount plates from a XJS that had a AJ16 engine in it for the front location of motor mounts. Do what ever you need to do to get trans mount to fit. I can send pictures if you need them. Send your ECM to XJR engineer on this forum to delete security feature in ECM. Use same shift cable. I,ll stop there and wait for more questions.
The following 8 users liked this post by Larry Louton:
anjum (07-05-2020), Coventrywood (07-05-2020), Doug (07-04-2020), jag Simon (07-05-2020), Jag7651 (07-05-2020), Jahmiata (07-04-2020), Mkii250 (07-05-2020), philg64 (07-19-2020) and 3 others liked this post. (Show less...)
Old 07-05-2020 | 09:20 AM
I stand corrected. Larry's looks awesome. That guy in the Jaguar Journal is going to be really pissed that he paid a fortune to have his front crossmember butchered when he could have just used one from an XJS! Good luck with the conversion. Please keep us posted with lots of photos.
Jeff
Old 07-05-2020 | 04:04 PM
Mkii250's Avatar
OMG your underhood is beautiful. That's an apex Jaguar.
Old 07-05-2020 | 04:36 PM
jag Simon's Avatar
Doug ,thanks for the info. It turns out that North American cars had no immobilzer. I disconnected the module and the car runs fine with no warning lights!
Old 07-05-2020 | 04:38 PM
jag Simon's Avatar
Thanks Larry, I like the positive response. I will keep pushing on.
Old 07-05-2020 | 05:50 PM
Fraser Mitchell's Avatar
ALl my best wishes for success in your conversion. Nice for somebody to be willing to keep a Jaguar "all-Jaguar". The AJ16 was probably the best engine Jaguar ever built.
The following 2 users liked this post by Fraser Mitchell:
littlelic69 (07-07-2020), Mkii250 (07-07-2020)
Old 07-05-2020 | 07:13 PM
icsamerica's Avatar
You want to punt on the X300 and get a 94/95 XJS. Preferably a convertible so you can use the X braces too. It's nearly a bolt in and only a few custom parts are required when using an XJS. I've done it with working power and heated seats, working ABS, working Air bag, wiper logic, and sport mode. All the minor things like brake lines, HVAC system, blower motors A/C hoses will work out.
You can PM me your phone number.
https://bringatrailer.com/listing/1976-jaguar-xj6c-4/
https://www.jaguarforums.com/forum/x...2017-a-184891/
Old 07-07-2020 | 08:16 AM
littlelic69's Avatar
I believe it was built at the Ford factory in Bridgend South Wales!
Old 07-07-2020 | 12:24 PM
Well, this may be true, but the AJ16 is a development of the AJ6 which goes back to pre-Ford Jaguar, back to 1984 in fact. I think Jaguar built engines in the old Daimler works at Radford in Coventry. Certainly a lot of machining was done there.
https://www.jaguarheritage.com/jagua...6-aj16-engine/
Old 07-07-2020 | 05:36 PM
mikega's Avatar
Kindly put all the practical procedure together as one document in step by step as done with the conversion and share with us.
My proposal.
Mike
Old 07-07-2020 | 07:14 PM
I used a plumb bob and large sheets of paper taped to the floor to measure the size of the 4.2 engine in place, Then rolled the engine/ trans on a wheeled pallet in place to see what was going to clash as far as sheet metal, bulkheads and other immoveable items. I knew ahead of time about the motor mount plates up front would be a unmovable location point. Remove 4.2 engine, Install motor mount plates from XJS and install 4.0 AJ 16SC engine.
Install rear trans mount, Shorten drive shaft, Align and level. For the center exhaust pipe I used a "Y" pipe from a series three but flipped over and bent to fit. A/C condenser is from a XJS. A bunch of real small fittings then I was on my way. The ECM failed on me recently and decided to fit a aftermarket unit from EFISource. It's like a brand new world.
The following 2 users liked this post by Larry Louton:
Coventrywood (07-08-2020), Jahmiata (07-07-2020)
Old 07-18-2020 | 02:52 PM
JaguarSpecialties's Avatar
Former Sponsor
Default XJ6 and (California?) AJ16
Hi, this is Andrew from Jaguar Specialties- I just noticed this thread and read it with interest. What caught my attention is the fact that this is all happening in California, and I have a question.
I noticed that the XJ6C in question is a 76 which means that it could be subject to California emissions. Are you located in a county that has the biennial emissions tests? Or are you outside of that? (lucky you if you are....). If this is a car that will have to be tested regularly, you may first want to have a conversation with the California BAR (Bureau of Automotive Repair) referee center. To be legal in California (and I'm not saying this combo cannot be) the car has to be put together properly, etc.,. and the BAR has guidelines on what is acceptable and what not. It's important to know all of this upfront to avoid (costly) frustrations later.....
For example, were you aware that only the factory air intake system (from the donor car) would be legal to use on this install??? Only factory programming in the computer is acceptable, and they check.... Little things like that
If you need info on this process, feel free to get in touch with me, let me know
Andrew
Jaguar Specialties
Old 07-18-2020 | 09:15 PM
I don't have those restraints' here in Florida but my install used a intact catalytic converter and the complete intake manifold but I ran into size restraints with the factory air cleaner? It would be up to Mr. Simon to take this matter up with California Smog board. The air cleaner was not a impossible problem to overcome, Just easier to overcome with a aftermarket unit.
Larry Louton
Quick Reply: Installing a aj16 into XJ6 coupe help.
