Intermittent stalling/Ignition Amplifier?
HELP!! My 86 XJ6 can run well for weeks and then unexpectedly it just just dies. The electrical system shuts down I cannot restart it. So far I have replaced both the pick up unit and coil. My best guess is that the issue has to do with something overheating or over stressed as it will restart easily after a cooling off period. Maybe a problem with the Ignition Amplifier?? What do you guys think?
Received 10,871 Likes
Inside the amplifier is an ignition module, AC Delco part number D1906. This is what typically fails and they're known for "Fails hot, OK when cool" behavior. As guesses go, it's a fair bet.
As Jose mentioned the ignition switch is also a common culprit although, in my experience, they don't share the hot/cool pattern of failure.
I don't, nor have I ever replaced one.
Over the years I've heard some say that "any condenser from a typical points-type ignition should work" but I really don't know
cel2620xl
16
08-08-2018 07:26 AM
Jaguar2986
03-09-2017 02:47 PM
