Issues I could use help with...
I already posted about my car just shutting off at the stop sign and we are working on that.
Whoever owned the car before me redid the headliner and it's loose around the sunroof. Are there clips or something to hold it up there?
Right speaker in rear passenger door clicks if I turn on the radio...it is the most annoying sound in the world. Any idea how to fix it, maybe it's a loose wire or just disconnect it.
I need a front left replacement on a fog light. Anybody have one for sale?
The trunk button in the car doesn't work and I am wondering if it has something to do with the valet switch. Any ideas?
The sunroof doesn't work. You can hear the motor working but it's not opening. Maybe a belt or something is missing?
I look forward to any and all replies!
Received 2,193 Likes
call crutchfield to get replacements and connectors. I got mine there(and new headunit after the stock 1 locked up)
valet switch is probobly set, use master key or remote to turn off valet.
you probobly need new sunroof tracks. theyre still avail at dealer but expensive to install as whole headliner, trim and sunroof assemly has to come out. its a 5 hour job
99xk8guy
06-05-2023 06:28 AM
