Jaguar 1983 XJ6
Jaguar 1983 XJ6
Hi Guys, I need help. Just bought this beautiful XJ6. The fuel pump was not working. Ended up putting a jump wire on the red diode next to the fuel pump relays and it fired right up. Took it out on the road and it ran smooth like a new engine. After about a mile or 2 it started to bog down when I gave it too much gas, then got worse and worse until I couldn't gave it any gas off idle. But if I pull over and shut it off for a minute or less it fires right up and runs smooth again, then after a mile or 2 stars doing the same thing.I would appreciate any idea you might have, Thanks Dave ,
Received 1,096 Likes
Doug (10-09-2023)
Received 10,989 Likes
The following 2 users liked this post by Doug:
David84XJ6 (10-09-2023),
peter J (10-10-2023)
"Doing the same thing" = brown gas comes out? Or clear gas comes out?
Brown gas = rusty gas tanks. Common.
You may have other problems with respect to engine performance but fixing this issue has to be the first step.
Daves
The filter I am talking about is inside the fuel tank and is not repeat not the in line fuel filter after the pump.
At the bottom of the rear fender there should be an access panel with a rubber bung.
Remove that bung for access to the small tank drain bung. Drain the tank.
Then there is a larger bung which can be removed which allows access to the filter which fits over the fuel pick up pipe.
If this filter is partially blocked the fuel pump cannot pull adequate fuel to keep the engine running.
After sitting for a while enough fuel may dribble through the filter to get started and run for a short distance.
NOTE Doug's advice re brown gas and a rusty tank. Your in-tank filter is probably getting clogged with rust.
You may also need to fit fuel filters between the tanks and the fuel pump.
The fuel pump has very strong permanent magnets which will pick up any rust particles and eventually jam.
The following 3 users liked this post by Bill Mac:
