Jaguar Series 2 XJC wheels size?
OE wheel is 6.5 inches wide with an ET of 28.5mm.
If you run a 7.5 inch wheel with the same ET of 28.5 your wheel center line will be the same and your suspension geometry and handling will be correct.
Since the lip of the rim will widen by 1/2 of an inch get under the car while safely jacked and make sure you have at least 3/4 of an inch clearance. Tape a block of wood cut to 1/2 of an inch thick to the lip of the wheel, spin it and verify clearances.
Also verify the center bore of your new wheels will be sufficiently large.
With a set of modern 225 series tires you will have one great handling machines.
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
PinnacleWax
Detailing / Car care
08-26-2015 11:44 AM
