Jaguar XJ6 Series 3 1980 | Gasoline Smell - Inside the car while driving?
Received 9,244 Likes
Gasoline smell GONE
Yes! I think I found the issue..
This "fuel line" comes back (retour) from the vaporator inside the C-Style.
I took apart the back seat and everything to find the fuel lines under the back window. The vaporator retour Line ends up in the trunk? I assume that normally these ones are guided out of the car??? Can anyone make a photo of their trunk? To show me where the line should go?
So the photo above was clearly my problem, did a bit of testing and smell in different places, and this hose smelled awefull. It's the return of the vaporator.
Connected it to the wheel arches? (Is that correct English?) And now the smell is gone.
SOLVED.
I read your article and I have a question.
My vehicle is xj Series2 5.3.
When I open the window while driving, I smell fuel. It seems it is a same symptom with your car.
Especially when I open the trunk, inside the circle marked area smells a lot. (a photo attached)
I've replaced hoses, connections, fuel tanks, and regulators with new products to solve this problem. (photos attached)
but It didn't work.
And this is the connection of my car's charcoal canister. (a photo attached) I don't know if the charcoal canister is connected properly. I think the wrong connection might be the cause of this problem.
If you've solved the fuel smell problem, please advise me what I'm missing.
magnetron
04-19-2018 02:50 AM
chadrm
11-14-2011 08:35 PM
