Just did a rear brake job
Well, today I started taking the IRS assembly apart. For the most part it was pretty straightforward. I found removing the nuts connecting the half shafts to the differential to be the most difficult part. Otherwise the other nuts, bolts and shafts came out pretty easily.
I still need to tackle the brakes and differential. Overall everything looks in good shape (except the leaking in the diff of course).
Eric
Eric
Received 10,871 Likes
Welcome to the Forum, if you will add your car to your posts by going to your "User PC" we will all know what you are working on. I am completely rebuilding my 1985 S3 and am on the rear differential right now. I have never worked on a Jaguar before and have found the factory shop manual to be indispensable. If you will read this thread from the beginning (2010), you will find all the info you need.
Dave
Dave
Received 2,399 Likes
For what it is worth. I've removed a JAGUAR IRS . I farmed the labor out. A bit of a tale there. The shop replaced the calipers and pads and pads for the hand brake. Rotors healhy. No more than the usual seeps from the differential
1. I chose rebuilt :loaded: rotors from Rockauto. Good price and no core charge.Other good sources, but with core issues.
2. Decades ago, I removed and replaced a couple of Corvair engine transaxles combos. . Different process yet quite similar. The first time I had no trolley jack. Only a pair of bottle jacks.
I used a 2 x12 x 48 plank as a working base. Placed against the underside. Supported by the bottle jacks. Lower a bit at a time. then to blocks and levers. and at the last on two pipe across the width. Rolled out . worked at ground level. On the plank. Reversed to replace.
Second effort. Later, another car. decades later. Trolley in lieu of bottle jacks.
Carl
Carl
Doug, do you know of a link that will show me all the parts of the parking brake assembly and how to put them together? I have an 88 XJ6 base and the entire parking brake assembly is missing on the driver side, and needs to be replaced on the passenger side.
Any help will be appreciated.
Phil
Phil
philwarner
09-05-2015 10:05 AM
