Key Broke in Door
Key Broke in Door
Hello everyone!
My question is in regards to my 1985 Jaguar XJ6 VDP. This vehicle has been recently moved outside after having been stored indoors for several months. I recently attempted to start the car after it was sitting for a few weeks and I couldn’t get the driver’s side door open due to the cold weather. I tried the passenger’s side and the key broke off in the door (ugh!). What’s the solution to this? Also, how would one go about obtaining additional keys for this car? I have the key codes, but am unclear about how to go about it. Also, I don’t drive the car in the winter months here in PA, but I do like to crank up my inactive Jaguars until the summer months arrive as to keep everything charged up. Does this process hurt anything long term? Thanks in advance for all your help!
Received 10,873 Likes
winterize
Any good main street lock smith should be able to cut you a key. The lock cylinder can be removed and taken apart and broken key removed. It may come out with a pick, strong magnet and WD40 when the lock thaws.
Frequent and short cold starts are hard on an engine. Opening frozen doors is hard on the seals. Sitting on cold leather causes cracks. I'd suggest you Winterize the vehicle if your not going to use it for the winter. The Jag is particular easy to winterize.
Winterize...
Remove the battery and store inside or simply install battery disconnect switch
Drain fuel tanks which is easy on a jag and / or put stabil in both tanks. Run the car with the stabil so it can get in the injectors and fuel rail.
Top off all fluids and change oil, run engine briefly with the new oil.
Wipe door seals with some silicone lubricant.
Put car on jack stands or slightly over inflate tires.
Treat the seats with a quality leather care product.
Cover the entire car with a breathable car cover. Flap it occasionally and remove any leaves or debris as you walk by now and then.
Leave it alone until spring so things like frozen locks and ripped seals don't happen.
All this should take two hours in the fall and will add up to less time & do less damage than bi monthly starts.
Winterize...
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
RaceDiagnostics
09-13-2015 02:22 AM
