Late XJS ZF steering rack conversion for the Series 3
Hello y'all so the car is now my daily driver after 2.5 months of wrenching and troubleshooting although the car still needs a couple of things. The car leaks power steering fluid so I said screw I'm just gonna replace the whole rack. It's likely the original thing anyway.
I've learned that later XJS used a ZF rack rather than an Adwest rack (I'm assuming my S3 uses the latter). I also read that the series 3 has the correct steering column joint to utilize the better rack and the ZF is the same size as the Adwest.
If this is all true I'm just going to go ZF. Other than the rack and new tie rods what else would y'all recommend I should get as part of this conversion? Thanks.
The ZF was only used on 92+ XJS and Aston Martin DB7. It will drop in with some firm hand bending of the pressure line. The ZF rack has much improved bushings so it wont benefit from poly bushings as the older rack did. The ZF rack will still move around a bit on the bushes but if you want razor sharp DB7 steering you can use aluminum shim spacers that limit the racks lateral movement just like AM did on the later V12 DB7's.
Greg in France (05-06-2024)
The JaguarSport rack bushings are still available, you need two, one each side and on the sie with 2 bushes, one normal one. They last for ever and are excellent, but pricey...
Number three here/
https://parts.jaguarlandroverclassic.../brand/jaguar/
Number three here/
Number three here/
Number three here/
Also is this the right ZF rack for it?
https://www.ebay.com/itm/27501168343...mis&media=COPY
The ZF was only used on 92+ XJS and Aston Martin DB7. It will drop in with some firm hand bending of the pressure line. The ZF rack has much inproved bushing so it wont benefit from busing as the older rack did. The ZF rack will still move around a bit on the bushes but if you want razor sharp DB7 steering you can use alumonul shim spacers that limit the racks lateral movement just like AM did on the later V12 DB7's.
You should not need shimming washers with the JS bushes. If for some reason you do, it is just a matter of inserting a washer of the right thickness to take up any slight gap between the bush and the subframe/chassis brackets holding the rack.
That rack looks correct to me. You may need the power steering lines too, to and fropm the pump to the rack.
enomadra
11-22-2023 06:47 PM
