Leaking carbs
Leaking carbs
75 xj12 hi can someone diagnose this problem when i connect the battery and turn on ignition fuel pours out at left and right carbs at the overflow pipe please and thank you i also have a ringing or buzzing sound seems to be coming from right underdash of passenger side of car thanks guys for any help
Received 6,327 Likes
Welcome to the forum Mirrorz.
Please post an intro in the new member area for a warm welcome and some useful info on navigating the forums.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Welcome firstly to the Forum.
Please do an intro in the New Members Area when time permits.
Also, where are you located????, as different markets have different stuff.
The guys/gals in the XJ S1/2/3 section will have more answers.
The needle and seat valve in each carby may be stuck. Particularly if the car has stood for any time, and the fuel has dried up in the carbies.
Then the list gets long.
Welcome to the forum Mirrorz,
I've moved your question from General Tech Help to XJ6 & XJ12 Series I, II & III forum. Members here with the same model will be able to help.
As suggested in previous replies, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Grant Francis (06-21-2017)
