"Leaky" fuel tank selector valve? (I'm getting fed up with this fuel system!)
Does your fuel tank selector valve leak gas from one tank to the other?
My left tank leaks gas when it gets above 3/8" full. This is usually not a problem but annoying. I simply leave the left tank pretty empty and fill up the right tank. Well, now it seems that if the car sits for a few days, the fuel tanks level out. The gas slowly makes its way from the full right tank to the empty left tank. I'm guessing that it leaks through the fuel selector valve located by the fuel pump. This causes my left tank to fill up, and leak gas on the ground.
I'm getting really tired of this fuel system, and I'm thinking pretty seriously about eliminating the left tank. I'm also suspicions that the fuel pump is getting gulps of air when I whip around a tight corner, causing the engine to almost die. (This could be an engine tuning problem - still not sure.) I'm thinking about replacing that left tank with a surge tank. This would allow me to submerge my fuel pump and make sure that I have a steady fuel supply - something critical for the supercharger I have waiting to go on. I hate to lose the fuel capacity and the novelty of having two tanks. I don't want to give up any trunk space to a fuel cell either.
Any thoughts?
Any thoughts?
I used a Pollak (6) port in my '72 LT1/700R and it works great...do not have any Jaguar switching stuff in any Jaguar....too much trouble.
Added clear filters from each tank before the valve (black thing) and since the photo, a fuel injection pressure rated filter after the pump.
Can send current photo with Summit fuel pump instead of Walbro (it died prematurely). Have a (3) port valve in my '71 383/200R that is carbed...
no problems whatsoever....
lickahotskillet (04-30-2016)
New petrol tanks are available here in the UK, try David Manners Group who ship to the US. They are not cheap, but not outrageously expensive either.
If you eliminate one tank you will be constantly visiting a fuel station, as each tank really only holds about 8 UK gallons. If you get the tank fixed and by fitting a US V8 engine you have dispensed with the fuel return lines used by the original fuel injection system, then you could just replace the changeover valve with a T-piece so the two tanks act as one.
Received 10,903 Likes
Any thoughts?
Any thoughts?
I have a really off-the-wall idea to solve your dilemma.
If the valve is leaking you *could* just replace it, you know
In 5 minutes of Googling I found new ones for as little as $62.00 and it couldn't take but 15 minutes to install it.
Your under no actual *obligation* to solve every parts failure by re-engineering the system, but feel free to do so at your discretion
Received 2,399 Likes
Comments:
1. A USA engine with FI needs a return line.
2. Subbing in a T for the valve is fine on level ground. But, don't park side saddle on a steep hill. The high tank fuel will cross to the low side, if there isn't enough room, it will run out over the side. Gas on the ground, just waiting to ignite!!!
3. it may not be the valve that leaks, but only the detiorated hose connections. New hoses and clamps???
Carl
Carl
deanh
09-06-2015 08:20 PM
