left headlight no light right headlight fine
Received 10,916 Likes
Anfield Dreaming (05-04-2015)
Received 2,399 Likes
Suggestion:
Make your self a test light. From simple to elegant.
Any small 12 v lamp socket and bulb. A black wire and a red wire. Solder and soldering gun. The probes can be most anything, from a pair o skinny nails to pices of clothes hanger wire.
Or, no socket, only a bulb? No problem. Solder the red to the contact tip of a bare bulb. solder the black to the brass body of the bulb.
But, in your case, the blown fuse is a strong clue. Over load somewhere. Fried a wire or connector til it is open?
A visual tracking might find that open.
Carl
Carl
Great news after giving up it,I decided to spend a bit of time cleaning all the spade connectors on the electrics and when o went to finish up I thought I would try one more time and they LIT UP!!! changed them over to a halogen set up that I purchased a couple of weeks ago and now we have LIGHTS! Thanks for the hell and patience. I still can't get my dash lights working but hey ho.
Great, it works almost every time1
I call it Jaguar Electric Mantra. clean, tighten and in some cases lube, connectors.
Or, a term, I am accused of coining, "electrickery.
But, make that test light. I grew up on them for lesser critters. Pre meter days for me.
I did make a crude VM. An NOS meter intended for an IHC truck. Made up some leads and probes. Still ion my electrics box. although, I now have analog and digital VOM's, somewhat recently joined by an inductance meter.
As, I am far from an electrical genius, I keep each in its original box replete with the use instructions.
Carl
Carl
