Light Behaviours
Series2 '74 XJ6, so how should my light act? have the dial for putting the head lights on at left of right hand drive steering wheel, right. then the indicator stalk for l/r indicators and for dipping the pitch of the head lights from 'high beam' to 'low beam' and vice versa. the stalk indeed dips the pitch of the lamps switching from illuminating the forward part of the bulb to the section further back and changing the apparent visual pitch of the head lights but it doesn't hold in place for what I guess is the 'high' or 'long' beam it just flashes the said 'high beam' before the stalk drops back to the 'low beam'.
should it sit in each position? it doesnt seem to be set up too. i cant seem any other way to set the headlight to a higher beam but then both high and low look like very low beam compared to modern head lights.
Received 9,204 Likes
My series 2:
Turn signal/headlight stalk, the following:
Left turn, push UP; right turn, push DOWN
Headlights: If the lights are OFF, pulling BACK momentarily flashes HIGH beams.
If the lights are ON, pulling back switches ON high beams, until pulling back again which switches to OFF high beams. Each time the stalk returns to its neutral position, forward.
However, I have recently needed to raise my outer lights to give more illumination at night on the open road.
If you don't get HIGH beam, you might have a faulty High/Low switch which needs cleaning or changing. I would try spraying WD-40 or similar through the opening before trying to take the switch apart. Easiest first and all that. Then I would order another Hi/Lo switch from everydayxj.com. or a wrecking yard. Only after all the Easy tries are exhausted would I even attempt to disassemble the switch; but then, I'm lazy like that.
The following 2 users liked this post by LnrB:
adenshillito (05-02-2016),
Daf11e (05-01-2016)
Received 3,939 Likes
The following 2 users liked this post by Daf11e:
LnrB (05-01-2016)
Each time you pull the lever back you are operating a latching relay that is located near the headlight fuse box (large alumunium relay).
The relay has two sets of contacts. One operates momentarily, and lights the high beams for flashing when the headlights are switched off. The other set of contacts lights the low beams via the headlight switch when you turn the lights on, and provided changeover to high beam.
When you operate the lever to go to high beam you send an earth pulse to operate that relay, it turns on high beam via changeover contacts and latches in place mechanically so you only have to flick the lever. Flick it again and it toggles back to low beam.
Looking at what you have described logically:
The relay sounds like it is operating OK, so everything should be OK from the lever out
Sounds like you see high beam flashing so that cct and fuses are OK
Low beam works OK so you are getting that 12V
High beam not working, but you see a short flash from the momentary contacts as the relay cycles.
Sounds like you may have faulty changeover contacts in the relay. The wiring to high beam from both sets of contacts exits on one lead and is joined in the relay.
Options are to take the relay can off and clean all the contacts, replace with used/new (maybe Everyday XJ if you have trouble in sourcing in NZ) or convert to a generic relay.
The other option is that I am completely wrong as I am basing the above on my S3, but I think headlight wise they are the same. I have mine dismantled at the moment to put in a relay to unload the light switch, and a generic relay to do the headlight switching.
It does seem like the dipping of the lever provides a high beam for just a moment before recoiling to original position and low beam. should the lever not be able to be clicked into a holding position here?
Or is it entirely down to the relay to do all the work, therefore something at the relay is not handing over function just flashing momentarily?
Am I understanding right then that each flick of the dip lever forward should toggle the mode between LB and HB until the never dip of the lever?
thanks
thanks
If this is the same as the S3 as I suspect, the relay is doing the work. The lever just sends a short pulse to the relay which changes it from one state to another.
The relay has two sets of contacts. One that handles the flashing and one that does the changeover.
Dont really understand the last question, but yes all functions are activated by a momentary pull back on the lever. Just note it is possible to damage the relay buy holding the lever back for a long period.
To test the flash function just pull the lever briefly towards yourself with the lights switched off. You should hear the relay click and the high beams should flash.
You only notice the flash now when testing the dip function as the high beams dont stay on as they should and are just overlaying a brief flash over the high beams.
adenshillito (05-12-2016)
Received 2,399 Likes
Odd, oh, for the days of the simple push/pull head light switch
and a dimmer pedal on the floor board????
Those stalks still perplex me a tad. I do manage though.
Except for the momentary high beam flash. Seems antiquated.
In olden days, on two lane roads, we signaled an intent to pass with a flash of HB.
Carl
Carl
Alli Quinninho
12-22-2020 03:00 AM
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
WTB[Western US]: Left Rear Bumper Over Rider for MK2
tedwone
04-06-2016 01:47 PM
FS[Western US]: XJ6 XJ6C Rear Valence Panel- NEW, Never Used
XJsc-guy
04-05-2016 10:11 AM
robearner
04-02-2016 03:51 PM
