Light fault warning light
Is it normal for the yellow light fault light on the dash to light up when you first turn on the lights? I've been running laps around the car looking for one of the lights not to be on and all of them are on. The dash light will go out after a few miles down the road...
Todd
Todd
Received 10,916 Likes
Perfectly normal. The bulb failure sensors have a bi-metal switch that is closed when cold. It take a few moments of current running through them before they heat up enough to "go open" ...and then warning light goes out. Then, if a bulb fails, current is reduced, the switch coold down and closes...and the warning light come back on !
if the light does go out after a few miles,it sounds more like a bad Bulb Sensor, instead of a bad bulb.
I understand these Sensors have an adjustment screw, although I have neveradjustedmine, the light always goes out after 20 seconds.
But we don't know what year or model car he owns, do we?
