Looking at an 86 XJ Vanden Plas
it looks like a VDP. The sill plates are correct, the gauges are sunken, which is correct. The Leaper was an owner or dealer installed accesory, no Jaguar came with Leapers from the factory since the 1970's
the auxiliary fan only runs when the temp reaches and passes a certain temperature. On the 12 cylinder engines it runs continuously.
the two front seats are not Jaguar. Look like Toyota seats.
the wire wheels are not Jaguar original wheels, it would have come with Kent wheels. Those look like Daytons.
Thanks Jose! I've found a couple seat assemblies a couple hours south of me for less than 100 each, may get a deal if I get both. I'll have to see about why the fan runs continuously. I've already been in contact with David at EverydayXj and it seems like he's got a majority of the interior parts that I need. On the bright side. I'll have 2 lounging seats for the garage now! LOL.
Thank you for all you're guidance and advice so far! I'll probably start a build/progress thread once we I start getting stuff shipped in.
WAIT!!
are you saying the aux. electric fan runs whenever the a/c or heater is ON ?? Or does it stay running forever even if you turn the engine OFF ??
I ask because back in the late 1980's and through the 1990's there was a popular modification to make the electric fan run continuously in the summer heat. I did it to my car too, but it is a noisy modification, that electric fan isn't exactly quiet, and in fall and winter weather you don't want that electric fan running at all, so the mod needs to be disconnected when fall arrives.
Poloskie (01-05-2019)
the giant fan behind the rad runs only when the engine is on, but is on 100% of the time the engine is on. . So its possible its modded to have it run all the time then? Interesting... Do you recall what the modification entails? Also, Do you know of an easier way to see if the stakedown kits installed other than taking the valvecover off?
Received 10,989 Likes
That's a belt driven fan so naturally it spins whenever the engine is running
The electric fan is in front of the radiator, maybe 10" diameter
The VIN will tell you definitively whether your car left the factory as a VdP.
If the fifth character is a ‘Y’ then you have a VdP; otherwise, it will be a ‘V’ which denotes a base model.
(n.b. I’m referring to the North American VIN, which is found on the A-pillar plate at the windshield and presumably on your title/registration—NOT the one stamped into the metal at the cowl under the hood.)
Either way, enjoy the project! It looks like fun.
Andrew.
Andrew.
#30
Congratulations on your new project!
It seems quite good to start with.
Be sure to check / replace all the rubber fuel lines, ignition wiring, plugs etc.
The work on the door handles tells me that somebody without "Jag-Knowledge" has been "working" on this car though.
The tops normally just slide off, so that will be an easy fix.
The woodwork and the headliner are shot, which usually points to moisture inside the car.
Check the sliding roof drain tubes for damage / clogging. That's what usually does this kind of damage...
The roof motor CAN be fixed, even when it is rusted fix internally........ been there, done that
For the wood work, you might want to check my XJ12 Sovereign restoration topic on this list.
If you do what I did, it'll look real, it'll feel real, but will never disintegrate again.... ;-)
Here's an example:
Interior "wood" restauration
Back in the car, matches nicely with the dash...
It's not wood, it's actually a plastic foil with a burled walnut print. Clean the surfaces, apply the foil very precisely, buff it very lightly with the finest scotchbrite and apply several coats of clear coat....then it'll look just like this.....
The body trims don't look original to me, but I'm over in Europe and things can and will differ from market to market.
If you get to the actual body work and paintjob, you might want to consider a pin striping, or the European chrome trims (they are still available through SNG Barratt's):
Have fun with this (soon to be once more) beautiful cat!
Pat
Here's an example:
Pat
#31
Thankfully all the windows and sunroof motors still work well! Thanks for the words of encouragement too! The door seals are where its leaking I think. as a couple of them have a goot 2-3 inch gap between the ends -_-. Ive got a ton of stuff on order, plugs coils, rotors, and pads. Once they all come in I'll start in on the project thread. And yes there was definitely moisture in the car. I've pulled all the floor insualtion and carpet and put a few damprid canisters in there to pull out the extra moisture. It's beginning to smell less like a wet shoe, so thats progress!
#32
Old Jags actually do have their own distinct (or is it distinguished) smell....( and no....it should not be a fuel smell .... )
The door seals can be a bit of a bitch when replacing.....don't ask me how I know, but they too are still available from SNG Barratt's for a reasonable price....
If you run into anything on the body side....just holler....I'll be checking in here every now and then ....
Poloskie (01-07-2019)
45Wheelgun
25
03-03-2011 02:41 PM
Mike2288
05-06-2009 01:47 PM
